Alkujaan tämän lähetti
Bikeradar Forums
9 speed cassettes go on a Shimano modern freehub without the need for spacers. Shimano 10 speed cassettes are actually smaller than 9 speed, as the spacings are narrow and go on a Shimano 8-10 speed cassette with a spacer, which is provided with the cassette (Tiagra does not use the spacer). They also go on the newer 11 speed Shimano freehub, as long as the 1.8 mm spacer (as included with the hub) is used in combination with the tiny spacer provided with the cassette. Also 9 speed Shimano cassettes and 8 speed will go on an 11 speed freehub using only the 1.8 mm spacer.
If you have an 11 speed Shimano cassette, this will only go on the new wider 11 speed freehub.
